Old August 18th 2006, 08:08
flat flat is offline
Wally,
I'll try and make the adjustment both ways.
But, as a thought, have you tried the offset sway bar bushings? They pull the sway bar pivot forward, which will pull the lower control arm forward and afford a little more caster. I have those on my 1302, and don't have any issues with striaght line stability (upto 100 mph). If you 'overdo' caster, the steering gets really heavy. Depending on your wheel size and steering wheel size, it can be a bother.
I'll keep you guys posted.
www.vdubengineering.com
