Old September 12th 2006, 06:52
56oval's Avatar
56oval 56oval is offline
rich I will over the top ,the bottom if I have enough clearence to remove the transmission.
Old September 14th 2006, 01:49
Humble's Avatar
Humble Humble is offline
I thought I had a lot of fabrication in my project but when I look at what your doing my car isn't so tough anymore Keep the updates coming!
Old September 16th 2006, 08:51
56oval's Avatar
heres the bracing to bridge the torsion tubes together and the engineer has approved it.
this will be the position of the drive shafts under load.
[IMG]http://i55.photobucket.com/albums/g158/malcolm_05/IMG_1041.jpg[/IMG
cheers malcolm
Old September 16th 2006, 08:53
56oval's Avatar
another angle
cheers malcolm
Old September 17th 2006, 17:33
Looking good Malcolm, but I think you could get a LOT more strength into the middle by closing off the hole infront of the trans...
Rich
Old September 17th 2006, 22:32
56oval's Avatar
Rich the hole in front of the trans is forthe shifter rod & coupling if you have a look at the earlier pics youwould see that plate goes right across the tunnel.
I,m going to modify the orignal pan and use this one as a test bed.
Old September 18th 2006, 03:40
Another thought... I wonder if you could make the front trans mount structural? That would keep it removable, just have to think of a way of getting some rubber back in there..
Rich
