Old December 20th 2002, 15:33
Pillow's Avatar
Pillow Pillow is offline
Hey Joe,
If you got the spring plates and control arms the only thing you would need to add is the stub axle and bearings. Then put on the rear IRS brakes of your choice. Pretty easy really as there is not much to these things.
I have to check on what adjustments are on the plates and get back with you.
With the 1303 front lower arms and Kersher ball joints I think the 944 spindles will bolt right up making the 944 brake conversion a snap.
Hey Julian,
I am not sure what you mean by "rr" hub in the question? Is that Right Rear? The only 944 front hubs I might have FS are from a '84 944, reluctant sale for $75. Has studs still in them.
Thanks,
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
