Old November 1st 2006, 17:56
aircool aircool is offline
Like these-
Old November 1st 2006, 23:33
MikeVW's Avatar
MikeVW MikeVW is offline
You could make your own die. Use hard wood and make a male and female piece with the taper in it. Drill the hole to the size you want and then put the male end on the outside and the female on the inside and tap with a hammer. Give it a shot on a piece of scrap first!
Mike
Jack of all trades and master of none!
http://www.Type1R.com
Old November 3rd 2006, 07:22
Chris Percival's Avatar
Cut the holes with a whole saw, then use this tool from Frost:
http://www.frost.co.uk/item_Detail.a...0Flare%20Tools
A good hole saw and that tool could be used all over your vehicle..
Old November 8th 2006, 17:25
Thanks Chris, frost's is a really cool shop!
Old November 9th 2006, 03:33
Expensive though...
Old November 15th 2006, 23:37
Zman Zman is offline
Question
Has anyone made the back panel between the rear fenders removable for easy engine installs? I have seen them in pictures from Remmele, but didn't know exactly how they did it as far as making it attachable back. I figured they welded some flanges just below where they cut it and used pins or a cool screw type holder to reattach it.
Gary Zimmerman
69 German Looker T4 2270 Raby Kit
Old November 16th 2006, 01:00
Bullyboy Bullyboy is offline
I used the method on this website
http://www.geocities.com/eaallred/project64Main.html
pretty simple and you can't tell its removable
