Old December 25th 2002, 00:22
chigger chigger is offline
Thin wall tubing would be like conduit tubing. Less than 1/16 inch thick. Thick wall tubing is like what is used for the tie rods to fit in. It is usually about 1/8 inch thick wall and sometimes it also comes with just a small hole in it down the middle. A machine shop is a good place to look or even the junk yard. Look for some tie rods that are hollow. I don't think a VW tie rod is long enough for the long rod. But it is long enough for the short rods. You can also use metric taps. The steel tubing is not really that heavy.
