The 5x112 pattern looks like a modern pattern (VW Passat amongst others) to me. If I am right, you would probably need blank drums custom studded. One word of caution with modern bolt patterns: Make sure the hub size of the drum is compatible with the hub hole of the wheels you want. I had to make concessions with my front wheels when I chose a modern pattern for my disks. The best quality adaptors will likely add to the amount of track you have on the front and on the back. Since you seemed concerned about modifications in your post, this could lead to some especially if you chose a wide wheel as well. These adaptors won't be cheap either. Even then, there will be those who will strongly recommend against it -- some in general, others in a racing application. I am sure others with more experience will chime in.
(2004-2008): 1971 1302 w/2056 Searching for a new project ... |
Well the rims I really like, reason I am interested in whats needed is I want 15inch Randars.THere 15x5's and they have a 3.5" backspace.The addapters I found were 1/2" thick and cost 55.00 a pair. I would more like to have the 5-205 drums, an there is a aftermarket with them but not sure if I can use my bearings and backing plate with them. I was told to get wide 5 drums for front, and rear brakes from a Type 3 or Thing.
Heres a link to the wheels http://www2.cip1.com/PhotoGallery.as...7;2DC10%2D6657 |
Man, those adaptors are either a very good price or less than desirable quality. I would be concerned. I would investigate the backing plate and whatever else might be at issue before I would consider the adaptor route. If you go with adaptors, I would be more concerned with quality of manufacture than just its thickness. That is one area not to be frugal. My opinion only.
Any ideas of anyone else that may carry them, but a good quality, possibly? |
They would be custom made to your order.
Highly recommended are: http://www.motorsport-tech.com/index2.htm and http://www.wheeladapter.com/ My personal experience is with the latter of the two.
Im thinking of going with the addapters, reason being, if I want to ever go back to the stock size I can.Plus Im looking at the 5-112 pattern and under the 2006 Jetta, theres some nice wheels.Thing is, lets say the addapter is 1/2" thick, what ET rim would I want to look for?Would I want a 15x6.5 in a 40-55et or a 30-40mm et?
http://www.tirerack.com/wheels/Wheel...6&autoModClar= |
If you are interested in '06 Jetta wheels, you should find out what their offsets are. It is easier to work out these problems if you can reduce the variables into being constants.
