Just found some software to do corner weights, I used weights that Chris posted. Steve
STI powered 1303 in the works. Last edited by Steve C; May 1st 2007 at 22:20. |
Instead of purchasing such a scale, simply contact a local shipping/freight company and see if they have such a thing. If not then your local Co-Op should, since they have to have some way to weigh their grain trucks. If MacGyver could build a nuclear powered submarine out of a waterbong, a paperclip and a ball point pen, then this should be easy.
Hi AggieDave
Your idea would work in a fashion. What I was getting at by upsetting the suspension is, as we all know the suspension will slightly tuck under during lifting and the only way to settle it back to the correct ride height is to move the car, this tuck would raise the suspension throwing out fine corner weight measurements. Steve
Get one scales and 3 dummy scales. Drive the car onto the 4 items, measure. Drive off, swap the scales around, drive on. K.I.S.S
fastbug.net | FastTrack Dub Club "Straights are the boring bits that link corners together" |
your car and scales need to be on a perfectly( or near to it) level surface. otherwise you will get incorect readings, theres no way around it period.
You can use adjustments for ride height to shift weight and you can also simply use dead weight (such as lead) to do the same. its all a balancing act. with adjustable 944 spring plates you can do a lot. the goal is to get your cross weights near 50%
FULL SPEED AHEAD, HARD AND FAST! Current cars: -74 Super Beetle -86 Vanagon Syncro -64 sunroof bug -73 thing |
So all the measuring, weighing, knowledge and skill about suspension on the mechanics side is tossed out by the worlds finest judge...the driver's butt.
There are cheaper corner weight gauges available which use a lever assembly that hooks under the top of the wheel rim. push to lever down to lift the car and then the gauge shows the weight.
http://www.merlinmotorsport.co.uk/SU...325/index.html but I decided I couldn't afford it.... |
Much cheaper to just go somewhere (like http://www.raceshack.co.uk) and borrow their corner weight scales.
Andy those units look like the way to go. Aggiedave, I agree about the drivers butt, corner weighting is one part of car set-up that is scientific, if your turning left and rigfht even weighting needs to be achieved, if your only turning left hand corners or right hand corners, corner weights can be set-up to suit the drivers butt and track. Steve
One set of bathroom scales and three garden pavers...?
aka VWCOOL '56 Cal Oval with IRS and a 1916 '68 Country Buggy. '76 fuel injected Cabriolet ..and a good ol' Aussie V8 |
