2ltr dyno results
had the 2056cctype4 on the dyno yesterday and made a awsome 145bhp at 6900rpm at the rear wheels with 129ft lb of torque
all this from a 30 year old push rod engine.biggest prob was on the last run the dry sump pump has broke a gear and sheared the drive so starveing the crank of oil, have got all the parts to sort this bar a 3 stage dry sump pump. anyone one know who makes pumps for the type 4 still? type 1 wont fit. cheers rob
Specs of engine?
brief spec is 71mm x 96mm type 4
stock crank and rods with arp bolts je pistons with deves rings 44x38 welded and ported heads with 911 exharst ports web 86c cam with lightwieght lifters 48mm throttle bodies and a dta ecu custom header 3 stage dry sump cheers rob
well i have all the bits to rebuild now
had a new drive shaft made for the oil pump an found a gear. new set of h beam 2ltr rods crank grind and polish with all new bearings. case has been cemical cleaned should have it all back together and back in this weekend. cheers rob
judgie was the crank damaged. Whats the reason for the regrind and polish.
big ends had been scored when the crank was starved of oil but no visable damage to the mains so just had them polished. so theres a freah service for the new shells to bed to.
cheers rob
