Old November 1st 2007, 06:22
DORIGTT's Avatar
DORIGTT DORIGTT is offline
You're telling me I can use a stock WBX flywheel and an upgraded Kennedy clutch package? Was the clutch for the 901 trans or for a VW trans?
Also, what starter were you using the 901 starter?
The reason I ask is that I've been given some (apparent) mis-information regarding what needs to be done to put a flywheel/clutch in my WBX / 901 setup.
