Old June 19th 2009, 02:42
Be carefull what you read on the inetrnet, as my above 'conclusion' was wrong!
The dented part in the middle is supposed to be there....
Originally Posted by effvee View Post
Question, in replacing the syncros and sliders, was it much to it? I to have the "I'm going to mess it up frear thing" I know I will need a trans repairman to set the gear mesh for the ring and pinion when I get the GT ATB diff. How about the linkages internally, was ther much to re-set them?
The synchros itself are difficult to get off and on. Lots of force and plyer-force needed iirc. Not fun; possible yes, maybe, just..
I didn't set linkages as I didn't loosen them, but I should have resetted it. Also here: you need to know what your doing. I had to open the tranny once more because of my inexperience...
Old June 19th 2009, 21:01
effvee effvee is offline
Tools
Walter, did you use any special tools? Press? indicators?
Old June 20th 2009, 02:56
No, not really, just an air socket/wrench (sp?) for removal of the top two nuts (41 and 36mm IIRC) of the gear stacks is very recommended as is an old clutch disk to bold into your workbench. Of course things like a good gear puller, of which I modded the fingers a bit, is without saying.
The special 915 jig to set linkages inside is recommended too. Pelican makes a replica in hard plastic, very cheap btw!
I am sure to have forgotten things, but this is just from the top of my head.
Old June 21st 2009, 16:46
Your new throw out bearing
Walter, concerning the I believe a Saab hydrualic throw out bearing that you modded to your G-50 setup. Do you believe this mod can be done to a 915 trans? Before I go any further in my 915 project, I'd like to know how I am going to address the clutch apply issue. I just noted your last dyno test, congrats.
Old June 22nd 2009, 07:37
1) I didn't use the Saab TO bearing in the end, but a Ford Mondeo (iirc) model as it was smaller.
2) AFAIK, room inside the 915 bellhousing is probably too small even for the smaller Ford TO bearing...
Old July 9th 2009, 19:59
Hi Walter, I'd like to re-visit the hyd throw out bearning again. So here goes, I am comparing your end results of shorting the bell housing area to basicly match the 915.
Since you did that, would the inside clearences pretty much be the same as the 915?
I really need to consider your method for your G-50 application in the 915. Because of the maching of the bellhousing. Where did you get the throw out bearning?
Old July 10th 2009, 02:47
Hello,
I'am afraid I can't answer your questions as i don't have the 915 anymore and the G50 is in the car so I can't 'have a look' let alone make a comparison...
In my remark 2) above here I think I already gave my opinion on your second question fwiw.
As for the TO bearing, I just bought a nice looking one on ebay
sorry,
Walter
