Old January 31st 2003, 17:13
Question Oil filler tube
Question.
I have a 914 case with FAT 911 cooling on a 2.0 GA engine. I was replacing the oil temp sender with the VDO unit to match my oil temp gauge and this is what I saw.
There is a boss for an oil filler tube that is closed off (Cast Over). When I have the 'Taco Plate' removed, I could put my hand in the opening and feel behind this boss.
Does this mean that I can drill out this area and catch all of the filings without splitting the case ? I could then install the studs for the oil filler tube with integrated dipstick.
This oil filler tube would transfer over to my NOS T4 case when I get the 2270CC built.
If I can do this then filling the oil with the FAT 911 Cooling system could be done through this tube and another problem would be solved.
Thoughts ? Thanks for any input !
