Some more pictures of different interior changes.
This is how it looked when I bought the car. ![]() Porsche steeringwheel and a 944 tach. under the dash. ![]() Raid steeringwheel and oilpressure and temp. gauges. OMP pedals, new carpet and I found an original frame to mount the radio. ![]() New panel under the dash for 4 gauges. I added a voltmeter and a tach.
All these changes still don't make it a Germanlooker. So after all the cosmetic changes I was ready to start on some handeling and braking upgrades. The last thing I needed was the right wheels with the right ET to fit the wide 944 turbo trailingarms in the back.
When I found a nice set of Cup 2's I could finaly start to work on the chassis. I already have all the parts I need but some parts are not jet instaled. The plans that have a - are the things I still have to do. Whith a + are already instaled. On the front. + 22 mm anti rollbar + Urethane bushings - Kerscher struts - 944 NA spindels for use of the original speedo cable - 944 S2 hubs - 944 S2 Rotors - 4 pot calipers for the 28 mm x 299 mm disks with the right cup size to create the right ballance with the rear brake setup. Rear setup + late 944 turbo trailingarms + New Zimmermann disks, pads and handbrake stuff + 944 S2 rear calipers + Urethane bushings + 944 S2 torsion bars + Yellow Koni shock absorbers - rear adjustable anti rollbar Wheels will be Original Porsche Cup 2 17" x 7 ET 55 on the front and 17" x 9 ET 70 on the rear. Last edited by Blizzard; April 21st 2010 at 05:00. |
To fit the yellow Koni's (which were made for an IRS beetle) on the 944 turbo arms I made a bushing from an unused urethane bussing for a 19 mm. front anti rollbar. The 12 mm. hole is to small as you all know for the 14 mm. Bold for the 944 turbo arms. So I made a 2,5 mm thick steel insert outside 19 mm. inside 14 mm.
Rear arm complete with driveshaft and disk.
![]() All the parts for the rear suspension before assembly. ![]() The rear suspension and brake parts on the car. ![]() Front is still under construction. This is what I can show you so far. 944 NA spindels with custom bearing bushes for the S2 bearings and a custom bushing to mount the steering rod on the top of the steering arm on the spindel. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I shortened 2 long (LHD right side) steering rods from a regular beetle to use with the 944 NA spindels and a rack and pignon steeringbox which is standard in a '75 super. On the left is a standard length '75 > steeringrod. In the middle is a shortened rod and on the right the complete custom length rod. ![]() I also made a pair of cradle's to support the new control arm joint while it's pressed in the front controlarm.
On the car.
![]() With the new 299 mm. disk and the 17 x 7 Cup 2. ![]() Complete side view of the car. ![]() The rear fenders are only 4 cm wider as standard so they don't fit over this rear setup. So I bought a pair of 7 cm. wider rear fenders from Kerscher. Last edited by Blizzard; April 21st 2010 at 15:47. |
My friends and I build a spraybooth in our hobby workplace so now i can paint my own projects.
![]() ![]() ![]() ![]() I also painted the Kamei spoiler again becouse it had some paint dammage. Because the fenders are 7 cm wider I also needed a wider rear bumper. It is a glassfiber Kerscher one that fits around those wide rear wings. So the front had to be painted also. I bought a new bare steel front bumper without chrome finish and painted it. The old chrome bumpers are for my '79 vert project. Last edited by Blizzard; April 21st 2010 at 05:05. |
The feshly painted fenders and rear bumper on the car. That's a 255/40 x17 tire you're looking at.
![]() ![]() The car stood still all winter so the rest of the car is very dirty. ![]() New front bumper on the car. ![]() Complete side view of the new look. ![]() The Black 4 pot Brembo's look great behind those Cup 2's
