I`m wondering if the Talbots would fit the Kerscher disc. Probaly not, but woudl be nice to verify it.
My current setup is Talbot front calipers, cross driller discs, type3 rears with 19,05 pumps |
The Talbot Horizon calipers were for solid not vented discs. it would be easy to check. Press the pistons back into the caliper body and see how much space you have between the opposing pistons, subtract the thickness of the pads + 0.03" clearance and vthat will give you the thickness of the disc. Then you will have to get all the specs of the CSP disc to see whether you will have to adjust the mounting position of the caliper.
Its all a lot of work and a bit hit and miss for no great benefit over what you have at the moment. Clive |
