Old December 21st 2010, 12:54
judgie's Avatar
judgie judgie is offline
looking for rings
Need set of rings for some 102.9 mahle pistons in a type 4 engine. Have tryed everone in the uk but have come up with nothing.
Any one got any ideas?
Tryed e-mailing BAS but no reply.
Cheers Rob
Old January 18th 2011, 04:20
judgie's Avatar
still searching for a set of rings, any one have any ideas?
Old January 18th 2011, 17:08
Calling Ahnendorp would be better (as with most shops, you know that of course). You do need to know the exact the ring thicknesses though and the brand of the pistons would be good to know.
I am sure JohnC from aircooled.net can supply them also.
Old January 19th 2011, 04:26
judgie's Avatar
there the mahla 103mm pistons. no one does any replacment rings for them. have a set of total seal 103mm rings that dont fit and all the aftermarket ones are the wrong size.
I'll try ringing Ahnendorp again but allways seem to get the answer phone.
Old January 19th 2011, 11:02
Originally Posted by judgie View Post
there the mahla 103mm pistons. no one does any replacment rings for them. .
Mahle is the biggest piston manufactor in the world. I can hardly imagine an engine shop doesn't carry their catalog or can't get those sizes from a Goetze or any other good ring supplier.
Ahnendorp now carries a different brand pistons for 103, so they will probably not have any on the shelf, but you never now and I am sure they can also ring their (engine shop) supplier and order them for you.
Surely an engine shop in the UK is the more economic solution.
If you just have a broken one, I might be able to help you out as I have a 'broken' set of the mahle pistons with 'Motorsport' rings
Old January 19th 2011, 15:27
speedy's Avatar
speedy speedy is offline
I was talking to a vw tuner the other week and he said that mahle have stopped producing all things aircooled (barrels rings etc) since they stopped producing aircooled engines in South America last year. I can imagine if this is true that they would be like gold dust .
J
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old January 19th 2011, 16:54
They are not specific aircooled at all. I even got some specific for nikasil 103 cylinders, which was a tiny bit more difficult.
Your not looking really for 102.90mm rings I suppose? The rings are sized by the cylinder bore which is very likely just still 103.00 mm, but I am sure you already knew that ;-)
Old January 20th 2011, 04:29
judgie's Avatar
they have to be mahla rings as they have used a unique size for there own pistons. no markings on the pistons bar the bore sixe which is making it hard work to match them to anything.
have tried everone in the uk and stateside tuning rang everone he knows to try and find a set.
i only really need 1 oil ring but a set would be better as there is some wear on them.
the total seal set i have is i think for j&e pistons and the rings groves are not deep enough for the rings, plus the second and oil ring are the wrong width for the pistons as well.
Old January 20th 2011, 06:04
Which is?
Old January 20th 2011, 11:08
judgie's Avatar
oil ring which is the only one i need is 3.97mm high x 3mm wide for 103mm bore. its the solid type oil ring with a spring inside it.
Old January 20th 2011, 14:17
Ok, I'll have a look around what I have in the pistons I kept
Old January 20th 2011, 16:53
As I expected somewhat, they are made by Goetze. See pic for sizes and shape. I think this is what you meant? I kept the original box these came in...yeah, I am a freak
Did you break one while installing? What happened?
You can have this one free of charge. Lemme know if you can use it and I'll post it to you
Old January 21st 2011, 04:29
judgie's Avatar
Wally your a star. engine came to me to be built after being striped to put a bigger cam in it, that never happened and somewere along the line a oil ring got broke.
I'll PM my address over to you.
Cheers rob
Old January 28th 2011, 09:10
judgie's Avatar
just want to say a big thank you to wally for sending me a ring. i can now finishing building this engine. seems you cant get new rings for these pistons.
cheers rob
