#106
Time to take out the old grinder again
. I really need the parts for my oval, but still it was difficult to cut up this nice '58.No way back now. ![]() ![]() ![]() Paul.
#107
After a lot of drilling, the dash is out.
#108
Hey,
How is it going? any news? ![]() Stevo
german-ghia.blogspot.com |
#109
Hi Steve,
I am very buisy wright now drilling all the spotweld of the donor car, no pictures yet. Als had a very cool weekend at EBI #4. Paul.
#110
The EBI Chimay weekend was superb, but now it is oval time again.
Al the old repairs are cut out of the donor front and today I started cleaning the underside of it. This is a very good piece of German metal. ![]() ![]() ![]() Paul.
#111
Finally did something visible again.
Complete parafan removed. ![]() Took a wile to find the currage, but it had to be done. ![]() Both doorpillars removed :shock: :shock: ![]() ![]() Paul.
#112
a few holes.
Looked at an original , never welded body and then circled all the original holes. The rest has to be welded. ![]() How it should be. ![]() After storage for many years, this all original (only the exhaust cutouts are not original), rust free and never welded oval is my workshop neighbor. now i can check it if I need to know how things should be. (i am not aloud to touch it ;D) ![]() Paul.
#113
Replaced the right windshield heater thing and repaired the left one.
![]() ![]() In the past someone drilled a lot of holes in this car, today I fixed it. This is a difficult to reach area, so while I was in there I might as well bare metal it. ![]() ![]() Paul.
#114
nice
#115
Getting close 8)
![]() ![]() Paul.
#116
My hat is off to you. Lots of metal work going into this one.
#117
Really nice (and quick too)
1967 Bug |
#118
Thanks Guys,
I am not afraid of doing new things. this kind of work is new for me, but i'll get there. Paul
#119
Satrting to look good.
![]() Right side is getting there as well. ![]() Paul.
#120
Between family live, work and some work on my daily passat, the oval is going forward as well (slowly).
Bolted the nose on the body, now i can see better what to do and where to do it. It looks like the right is OK. ![]() ![]() On the left I had some fitting problems, probably the welds from the pedalbox where to hot. I cut out the piece that did not fit and welded in a bigger piece instead. ![]() ![]() Still needs some welding, grinding and sanding. Paul.
| Currently Active Users Viewing This Thread: 12 (0 members and 12 guests) | |
