As the car is more or less done now I thought I'd post a bit of a summary of the final spec and some finished pictures (still waiting to get a proper photoshoot sorted!). Just need to give it a clean ready for a trip over to Spa next weekend..
Body oMain body restored with new heater channels, strengtheners, bulkhead, etc etc oSpare wheel well modified to take main radiator and charge-cooler radiator oFuel tank extended, baffled and fitted with internal up-rated fuel pump (HRC 310lpm) oRear end removable on frame, VW bus inspection hatch above engine oFront wings: 2” wider in fibreglass oRear wings: 40mm wider in steel with forced cold air intake incorporated into left hand wing oK&N panel air filter built in to inner wing, with water drain oLengthened bumper irons with stock bumpers oRepaint in original colour (Schwartz Metallic) oGerman Sonnenland roof •Chassis oCustom framehorns, torsion housing central section removed oCustom perimeter frame rails with one-off bead-rolled floors, finished in epoxy mastic 121. oOBP reverse mounted pedal box with twin brake master cylinders for adjustable bias and hydraulic clutch under false floor oFront: Kerscher coil-over struts, heavy duty anti-roll bar oRear: IRS with Protech coil-over dampers and swing axle length torsion bars, 944 anti-roll bar o19” Porsche Carrera Sport wheels, 10j rear, 8,5j front oVredestein Ultrac Sessenta tyres, 265/30R19 & 235/35R19 oPorsche 911 (996) brembo brakes front & rear oBraided hoses, 911 fluid reservoir. oSpacesaver 996 spare wheel •Powertrain oRebuilt subaru EJ257 shortblock (2.5l STI), forged supertech pistons, rebuilt V4 sti heads, ARP 11mm head studs, external oil breather catch tank, shortened/extended sump with RCM baffle plate, Garrett SC46 turbo, ported headers with custom 2” crosspipe, 3” bellmouth from turbo back, magnaflow 3" muffler, Nismo 740cc injectors, ESL daughterboard mapped by Bob Rawle, Aeromotive FPR on reversed parallel fuel rails, new-age subaru coilpack conversion. Estimated 400-450bhp, 450ftlbs. oCustom charge-cooler system with bosch water pump and Pace pre-rad, inlet manifold spacers/insulaters oCooling system modified to external thermostat with Pace sierra cosworth radiator, fans controlled by ECU o1989 Porsche 911 ‘G50 shortnose’ transaxle fitted with rebuilt 964 RS LSD (80/20). 930 CVs, aftermarket axles and drive flanges, KEP uprated Porsche stage 1 clutch (550ftlbs) •Interior •Square weave carpets •Heated Porsche 996 sports seats and seatbelts •Rear seat modified to clear transmission tunnel •Dashboard widened to fit early Porsche 924 gauges with additional Stack Oil pressure and turbo pressure gauges. Mini switches. •Seats and dash re-trimmed in saddle tan leather by Auto-trim, Leicester •Alpine CDA-X001 head unit, Rainbow component speakers up front in one-off fibreglass foot well enclosures, pioneer rear speakers in kick panels •One-off heater system built into stock duct system, stock dash controls with t25 fan switch & electronic Ford heater valve ![]() ![]() ![]() ![]() ![]() ![]() ![]()
http://www.ricola.co.uk |
