#301
A better pic of where both ends of the tube that supports the top of the Coilover of where they tie in at would be awesome.
#302
The gearbox has a special mount (bellhouse side). from this mount there are tubes going to the top of the main hoop. the torsiontube is narrowd therefore the body mounting point is on the inside of the innerwing (nrmally on the outside). I made the second tube from this body mounting point to the first tube (this makes a triangle). The schok is mounted to the tube that is going from the body mounting point to the first tube. Stil with me?
#303
Starting to look like a real cage.
![]() ![]() Paul.
#304
Cool! That will deffinately be 'Spa-froncorchamp approved' :-)
#305
Thanks.I am following the drag race rules (rules received from Rojo Racing) as good as possible.
#306
Another pipe added.
![]() ![]() Paul.
#307
new pipe update.
![]() ![]() Paul.
#308
Everything looks very good!
#309
Started on the cage part in the sparewheel area. First I made it with plastic pipes.
![]() ![]() Then copied it from steel. ![]() Attached to the cage inside. ![]() One down, one to go. Paul.
#310
Nice! I am getting close to the cage stage of my build so you help inspire me.
#311
#312
Bended the 2nd pipe. just a little fitting and it is ready. one pipe to go before the welding can start.
![]() Paul.
#313
Can you get the fuel tank out OK, looks close! The bends look good, what sort of bender are you using?
Rich
http://www.ricola.co.uk |
#314
Not sure about the tank yet. First I have to shorten the right tube a bit and tack-weld them. The bender is just a simple hand (hydraulic) pump. Paul.
#315
Impressive work!
| Currently Active Users Viewing This Thread: 11 (0 members and 11 guests) | |
