Old September 2nd 2018, 17:29
412STi's Avatar
412STi 412STi is offline
STi powered Typ4 in the works...
Hello GermanLooker
Wally asked me to write something about my project.
I want to fulfill this command, upps, this request.
As I have already said here https://www.germanlook.net/forums/sh...postcount=1497 and next,
my progress is very, very slow.
Now, only a little Teaser
Greetings Gerold
R.I.P. 1302/'72
Old September 3rd 2018, 02:54
Haha!
That is extremely cool!
Can you keep it under the decklid? Any pics of the Variant as it is now?
thanks!
Old September 3rd 2018, 15:18
412STi's Avatar
I hope it fits under the lid.
But in any case, I have to cut off the intake manifold.
We will see.
There are no pictures now.
Everything is still original but disassembled and must be welded here and there a little bit.
Now I first adjust the engine and transmission, so I can build the brackets.
Then I want to build the brakes, then edit the body.
Greetings Gerold
R.I.P. 1302/'72
Old September 3rd 2018, 16:40
Very cool!
(Psst: I like it so much as I am slowly preparing a rad build with a watercooled (6) unit into an early notch myself)
Old September 3rd 2018, 17:02
kai4130 kai4130 is offline
In the type 3’s variant world, the only way to retain the stock engine hatch height would be to make a custom inlet maifold to reduce the height of the engine.
With my notchback it’s more like a Karmann Ghia now with the rear boot/trunk area as the engine bay. Fare play not only for keeping a Type 4 on the road but the STI transplant also.... hats off to you sir!
Old September 3rd 2018, 21:49
chug_A_bug's Avatar
WOW... So Cool
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old January 8th 2019, 07:26
Bogara_ZO's Avatar
You are building the car i have always dreamed about! Good luck with the build
Old January 16th 2019, 19:05
412STi's Avatar
Cool
A little bit more.
As i said, my progress is very slow.
Real life is always in pole position.
The first two Pics showing the gearbox that gets installed.
Third picture shows my dummy gearbox with which I want to calculate the location and mounts.
Greetings Gerold
R.I.P. 1302/'72
Old January 17th 2019, 19:08
sheller's Avatar
sheller sheller is offline
What was the gearbox from?
Old January 17th 2019, 19:46
412STi's Avatar
5Speed Subaru WRX
Modified with Subarugear's parts.
Greetings Gerold
R.I.P. 1302/'72
Old January 18th 2019, 18:39
412STi's Avatar
Haha!
thanks!
Hi Wally
Because of pictures.
Found a few older ones, but not much has changed so far.
Was when moving into our hall, but have not been so much space for a long time
Greetings Gerold
R.I.P. 1302/'72
Old August 25th 2019, 15:06
412STi's Avatar
Question
Hello
I could use your help or input.
In my project, I have difficulty finding suitable drive shafts.
Unlike the Beetle or Bulli with Subaru transmission, the installation position is much lower and therefore I need shorter drive shafts.
Even the shortest ones available (Type3 automatic, left shaft) are still a bit too long.
You can cut drive shafts.
The special company that does that, only cuts hollow drive shafts. All VW or Porsche drive shafts I would like to use, are made of full material.
Someone an idea for a suitable solution?
Greetings Gerold
R.I.P. 1302/'72
Old August 25th 2019, 16:03
I suppose you really can only go with a custom axle then.
SAW makes those right? Probably only stateside companies do that kinda work...
Or Finnish.
Old September 5th 2019, 15:43
Clatter Clatter is offline
Sway Away still makes axles in any length you could want.
These are Empi, and cost a lot less.
Here with 1" narrowed arms and a 915 trans FWIW.
They have no inside shoulder/stop for the CV, so they are forgiving WRT length..
Old September 5th 2019, 16:41
H2OSB H2OSB is offline
Sheesh, Clatter, I didn't realize you were on here as well
Apologize for the slight hijack
johnL (aka H2OSB)
