#31
I'm not sure if the part number will help but these are the model cars that it fits
#32
Having trouble posting pictures
#33
A friend of my son is doing some fabrication for me. First thing he did was make intake pipes for the supercharger using the Mexican end castings
#34
trying again with photos
#35
That guy can weld and the 'packaging' looks very neat, lots of thought on your part.
Well done |
#36
Thanks. Ben is very good at welding stuff. He used to work for Hypertune
#37
Intake pipe done with DBW
#38
looking nice and plain!
VW Super Beetle 1303 1973 Kolibri Grün Metallic |
#39
I’ve been spending a bit of time on my Oval. Its now running a 1916 with a SC12 supercharger, Haltech Nexus2 ecu and drive by wire and a Flex fuel sensor to run E85. Its running a 4-inch narrowed beam with Monroe air shocks and bags on the back
#40
That looks absolutely fantastic
#41
#42
#43
I had the Oval tuned the other day on a dyno at Tunesmith
Engine specifications 1916. Stock heads 110 Engle cam (not ideal for a supercharged motor) and 1.25 rockers, Vintage speed exhaust. 4 LS coils, Dubshop crankangle sensor and CB cam position sensor. Haltech Nexus 2 ecu. 485cc injectors with a 5th injector before the supercharger and drive by wire. SC12 supercharger with custom pulleys. Best 98 RON run was 98.5 kW or 132 hp at 5550 rpm and 80% throttle. We then swapped to E85 and did a few power runs but a gasket leak at the inlet manifold prevented anymore power runs, but it still made 108kW or 145.6 hp at the wheels on 90% throttle. The best thing about the drive by wire is that the throttle can be used to limit boost. The drive by wire is also used as a rev limiter, it rolls the throttle off near redline before a fuel cut I'm using Mexican efi manifolds that were modified by Ben Wallker from Third Strike Fabrications
#44
Photo taken around 1am news day before loading he car into the trailer
#45
This car is so cool Steve, loved the instagram video you posted.
1972 1300 GL In Progress
| Currently Active Users Viewing This Thread: 13 (0 members and 13 guests) | |
