Old August 9th 2013, 23:06
noslzzp noslzzp is offline
Rise in the pan behind the drivers seat?
Paul, what's that structure behind the drivers seat? It rises up from the floor/pan.
Introducing the Basilari 306R - '59 low light, 300HP+, Mendeola chassis
http://basilari.com/
Old August 10th 2013, 16:13
fahrvergnugen fahrvergnugen is offline
Here's the chassis up side down, get it?
Paul.
If some is good and more is better, then too much should be just about right!
Old August 10th 2013, 20:29
SportyBug SportyBug is offline
Originally Posted by fahrvergnugen View Post
The new (used) coilovers where in. I just had to try.
This needs some mods.
Are the mounting points for the trailing arms in the stock location? I've seen this problem happen before
Old August 11th 2013, 04:00
What problem?
The rear is narrowed by 19cm. I had to cut of the framehorns to place the mounting points.
Old August 17th 2013, 11:31
Started on the cage today. With these holes I can lower the cage a bid and weld the up side.
Bending the bends in the wright position and keeping it straight is a PITA.
Did you see my special cupper angle measure tool ;D
Paul.
Old August 21st 2013, 08:10
De first hoop is in.
I made the connection to the gearbox mount with tape, this way I can measure the angle I need.
Paul.
Old August 28th 2013, 15:56
Cage fight
Paul.
Old September 8th 2013, 07:14
DAMN, why didn't I notice this before. After checking the cage measurements, I found out that the gearbox wasn't in line with the middle of the car.
So time to start over again. (attempt nr. 3)
Paul.
Old September 9th 2013, 02:38
Noooooooo! Oh, you mean the tranny mounts, ok, I had a flash of you starting over on everything, just don't know if I could handle it!
Old September 9th 2013, 17:03
LOL, it's just the tranny that need some work again. Just keep working on that awsome bugster or boxtle build and don't worry about my misstakes, I will make a lot more of them before I'm finished.
Paul.
Old September 9th 2013, 17:25
Love this thread.
Lucky you found the error with that trans mounting now.
Wouldn't life be so much easier if we didn't do all this stuff to old VWs, but it would be a pretty boring life.
Old September 11th 2013, 15:24
Love this thread.
That means sitting on the couch with the misses every day. Better have some gearbox troubles.
Old September 11th 2013, 15:25
Gearbox is in again. It is further inwards so I had to shorten the cage and framehorns.
Paul.
Old October 12th 2013, 16:18
Because of the higher mounted engine and gearbox, the luggage compartment had to be raised as well. This means that is had to be widened. I wanted to use a donor piece from 1954. Now I found out that even this part of '54 sheet metal is different to a '56 piece. But with a little help of a hammer and knee it starting to fit.
Paul.
Old October 16th 2013, 16:36
8 cm higher, it has become a short firewall
Paul.
