Old December 20th 2010, 16:04
dub_crazee's Avatar
915 Guide Tube
Hello,
Ive got what i think is an early 915 gearbox (code is worn off the bottom) and has a push in guidance tube rather than bolt on. I need to replace this with a bug@5speed conversion tube.
Ive done a bit of research but there doesnt seem to be too much info on the tube itself - but only the seal.
Am i right in thinking i have to remove the differential and remove the tube and seal from the inside?
Thanks for your help
Deano
Classic Car Revivals
www.classiccarrevivals.com
