Old February 2nd 2011, 01:02
kombi211 kombi211 is offline
IRS conversion and brembo's on 68 squareback
Well I have started now on the IRS conversion with the 944 alum arm
The parts being used for the rear are as followed:
944 alum trailing arm
944t axle assembles cv to cv
996 rear rotors
944 4 pot brembos
thing trans
modified swing axle spring plates
first i started off by cleaning the arm and painting them up
painted arm with new bushing installed
removed all swing axle tranny and cleaned 40+ years of grease and grim
new weld in brackets
I was going to use 944 trailing arm but i have ran into a little problem already my torsion bar are to short. So for now i will use modified vw spring plates till i can get some upgrade torsion bars ordered and shipped. ( I will post pic on the spring plates once I start on them)
With the Irs conversion its going to be a little different from a Bug conversion. 1st. being the typ3 has a removable sub-frame and the bottom of the torsion tube has a extra support welding on.2ndthe frame horns top half is smaller then a regular Bug tube. this makes the weld in bracket sit a little higher then the tube and not inside like on a bug.
What i done was cut the metal away from the bracket and just folded it up and out of the way to start with that way once the bracket is tacked in place. And its time for final welding i can trim the metal down and hammer it down snug and weld it to the installed brackets. well thats the plan for now. Being like i said the bracket sits out and above the frame horns..
once i have everything where it need to be. Checked and double checked and then tack welded... I will assemble everything to check fitment and alignment of the arms.Hope to do that in the next day or two. After that I am just going to remove the rear sub frame for the clean up and welding....
some updates pic's
test fitting arm on modified swing axle spring plate
checking alignment before fully welding everything up
Old February 2nd 2011, 13:50
Very cool! What sort of plan do you have for tires and fitting them under the fenders?
Old February 2nd 2011, 23:37
Well i am running 16" phonedials which have 205/55 on the rear. which are kinda close to the fenders. I might have to drop down to 205/45 to clear I will just have to see once everything is finished at that point..
Old February 6th 2011, 09:40
test fitting left side
cleaning up subframe
40 year old sub frame mount
NOS mount
seen better days these are the last 2 mounts i need to find.Being i have one good one might just have them cast in urethane
subframe painted in KBS ruststop
