Old January 24th 2003, 12:10
bug-er's Avatar
bug-er bug-er is offline
Question koni red bumpstops
Hey
Ive got some koni reds for my torsion beam bug. The problem is that the car is lowered quite a bit and as a result the konis are very near (read on!! ) the bumpstop when fitted to the car which isnt gonna do the handling any good. Has anyone else shortened the bump stop?? at the moment its about 3inches!!! i was gonna take it down to about 1.
i cannot see as it would hurt as ive been running the stock shocks with no bumpstop at all for 4 months now. I dont really want dropped spindles as i dont like them.
i would be grateful for any help guys
Cheers
Adam
Old January 24th 2003, 13:33
verbeekb's Avatar
verbeekb verbeekb is offline
Adam, they can be shortened a little bit safely. Or, replace them with a shorter bump stop of a harder type of rubber, most any piece of hard rubber with a hole in it would do. I did it with a pair of 968 yellow Koni's on the front of my Single Cab. Just make sure they -never- bottom out and damage the valving/adjusting mechanism down in the shock.
Hope it helps,
Brian
Old January 24th 2003, 13:54
bug-er's Avatar
so they can be shortened to suit my requirements just dont go wild?? 3 inches of bumpstop does seem to be a bit much. Ill do it down to about 1 i think, ill check when i fit em, just didnt want to damage em,
cheers
Adam
