Old February 10th 2003, 18:14
hot66's Avatar
hot66 hot66 is offline
Question BAS cams & lifters
has anyone used BAS cams & lifters in either their type1 or type4 motor?
Just wondering how they compare against web-cam cams?
project in progress
Old February 11th 2003, 06:21
Hi,
BAS sells the german Schleicher cams with cam wheel already attached and American cams of - I believe - Eurorace (an 'H' grind is one of them).
The duration is measured differently, so is hard to compare, but in gereral I believe that the Schleicher cams use more overlap (duration) and less lift as compared to the American cams. I have used a Eurorace cam some 5 years ago with type 1 like type 4 lifters (yes they did exist, no bushings needed) and after about 6000 km, they still looked absolutely perfect (wanted to do some mods to the engine case). The american cams cost less also.
For my new engine, I have ordered a split duration Webcam.
Succes,
