Old June 28th 2003, 07:50
30mm oil pmp
I need some help here! How much machining needs to be done on a GeneBerg 30mm aluminium oil pump to fit into a T4 case? I'm using a schleicher cam. Or can I buy a 30mm alumium pump which fit the T4 case without machining? Appreciate the help.
Old June 29th 2003, 23:55
kdanie kdanie is offline
I don't know about a berg pump, I used a Schedek (?) 30mm pump. It's probably the same though: The part of the housing that supports the drive shaft needs to be shortened enough not to interfear with the cam, the drive tang needs to be shortened to fit the cam correctly, the suction and discharge holes may not line up correctly so that would have to be corrected. I won't give the measurements because your engine may be different than mine and you need to make sure it's correct for your engine.
ken
Old June 30th 2003, 06:56
in the "forthcomings" series in VWTrends they briefly discussed this. check with jake. he does it all of the time.
Old July 4th 2003, 08:17
Thanks guys for the help.
