Old November 5th 2003, 18:21
judgie's Avatar
judgie judgie is offline
901
just brought a 914 box 2ltr tail shift.
what i need to know is,1;what ratios?and ware can i get some info on stripeing and assembly?
girlfriends dad is going to shot peen it all just need to strip it all down.
cheers rob
Old November 6th 2003, 01:04
If you got a lil time hang in there cause I'm doing the "911 901 with 914 gears" conversion as we speak and should be complete this weekend and if all goes well I'll have a tech article to go with it.
You might want to look for a early 911 tranny as well cause you'll need the nose cone, hockey stick, (if it's a early Aluminum case you'll need the)case and intermediate plate as well as a gasket kit for a early 911.
SNN
Old November 6th 2003, 18:50
judgie's Avatar
sounds good to me.let me now how you get on.
cheers rob
Old November 7th 2003, 15:58
CLKWRK's Avatar
CLKWRK CLKWRK is offline
I have an extra nosecone/hockey stick assembly, as well as an extra gear set, diff and case.
Bry
GL ghia restoration:
Old November 8th 2003, 05:41
Michael Ghia's Avatar
914 Tailshift
When stripping the transmission down... do your best to keep the gaskets in one piece. The gasket between the intermediate plate and the main case sets the backlash and mesh pattern of the crown and pinion so it needs to stay the same. Get some cheap micrometers and have yourself setup with lots of bench space and boxes and a camera.
They are pretty straight forwards and not difficult to rebuild.
Gear ratios are
1 11/34 = 3.09
2 18/34 = 1.88
3 23/29 = 1.26
4 27/25 = 0.93
5 31/22 = 0.71
Ring and Pinion 7/31 = 4.429
MG
Old November 8th 2003, 16:37
judgie's Avatar
cheers mike should of spoke to you fisrt.
know of any why in the uk that is good for parts?
also is thare anything that should be upgraded while iam in thare?
cheers rob
Old November 9th 2003, 05:02
There are lots of people who have been inside a 901/914 tranny. I don't know of any parts for sale... sorry. Make sure that all the bearings run quiet and that the syncro rings are ok etc etc. It helps to have looked at a few gearboxes to know what to look for but once you know... you'll reuiblding everyone elses
MG
