Old January 12th 2004, 12:16
barbe's Avatar
barbe barbe is offline
That porsche used 16"205 and 245
Vw 1303 superbeetle 1972
Vw T2 Baywindow Panelvan 1972
http://www.networkjava.net
http://www.escarabat.net
Old January 12th 2004, 20:36
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Did you mean to ask what Porsche?
Old January 13th 2004, 16:04
barbe's Avatar
Buy rims of porsche of 16"and ahead it goes 205/55 and behind the tire that puts is 225/50 and it does not fit, because the rim is but wide that the tire, for that reason is 235 or 245.Help
Old January 13th 2004, 17:41
njv's Avatar
njv njv is offline
hi
how wide are the wheels look on the inside of the wheel it will say 16x? what is the width then we can tell you what tyres will work ok.
cool
neil verdon 66 sqr on irs.
Old January 13th 2004, 17:42
eldavid eldavid is offline
Barbe,
How wide is the rear wheel? Since you say that your rear wheel is too wide for a 225/50, it is probably wider than 7".
Your front tires (205/55) have a diameter of 24.877". If you have an 16x8" rear wheel, try a 245/45 tire, which yields a diameter of 24.681", or a 245/50 tire, which yields a diameter of 25.645".
If your wheel is wider than 8", let us know.
-emerson
http://geocities.com/ex1zee28
Old January 15th 2004, 04:38
barbe's Avatar
7j 16 xs Et55 and 9j x 16 ET 70. But which to boxter has left because 9j behind segun specifications does not mount. Thanks.
Old January 15th 2004, 11:02
9j x 16 ET 70.
In that case, the closest match is 245/45/16.
-emerson
Old January 15th 2004, 11:48
barbe's Avatar
Talking
Merci.
But of which porsche mounts with this enormous tire?
Old January 15th 2004, 11:53
Merci. But of which porsche mounts with this enormous tire?
This one does: http://www.leonoff.net/pages/911/911.html
Front: 16x7 205/55/16
Rear: 16x9 245/45/16
Are those your wheels?
-emerson
Old January 15th 2004, 13:17
barbe's Avatar
Thank's eldavid y a los demas también
