Old March 6th 2004, 17:43
Alex's Avatar
Alex Alex is offline
high end 2.6 engine or parts for sale
New case, machined with new 39gr (42gr) lifters 30mm pump and smaller parts like sump etc 1200$ US
80mm Scat forged crank (2.0L journal size) with new 5.5" Pauter rods new 200mm flywheel, Kennedy pressure plate and "Who is your daddy" clutch from ACNet. You will get an extra set of aluminum rods 5.5" from Pauter as well. 2100$
Set of new 102 Nickies with JE Pistons with rings and ARP head studs 2000$
Set of new Engine Plus heads 50x41 with manifolds, valves, springs, retainers, rocker shafts and valve covers with Berg 2" header and new Ahnendorp stainless muffler system from the Käfer Cup series 2800$
Set of new Klaus throttle bodies 550$
New Porsche 90A alternator with 225mm 11 blade fan 450$
The crank is used but only needed polishing. I have new bearings. If someone wants the entire set....I have a cam for the the heads.....old German Formel V cam from Schrick. It was made for my by PTP from a new cam billet.
Ask for a package price so you save a a few 100$s if you are serious of buying the entire thing. All the parts are in Germany. If the someone in Europe wants the heads...there will be taxes on them because I did not have to pay for it. We can figure something out.
All parts are in Germany at PowerTuningParts
Make me offers.....if they are realistic.
