Old January 2nd 2005, 14:49
flat flat is offline
SB and BJ Caliper brackets for KG disk
VdubCustoms is proud to announce billet aluminum caliper brackets to 1302/1303 and BJ beetle applications. The brackets will bolt on without any spindle modification, and allow the use of stock KG disks and calipers. The 1302/1303 brackets are held in place with 4 bolts, while the BJ brackets use the 3 backing plate locations.
With these brackets, you can install disk brakes onto your stock height drum spindles without removing the spindles. It's all bolt on!
Caliper brackets and required hardware $C85/pair.
Pics comming soon.
www.vdubengineering.com
Old March 5th 2005, 21:36
Pics finally up:
http://www.vdubcustoms.com/Wedo/brakes.htm
Easy,
