Old August 4th 2005, 18:51
rip's Avatar
rip rip is offline
shock clearance
got a bit of clearance issues with the front end of my ball joing bug.
running:
1-2 deg of neg camber
spacers 9.5mm
wheel 17x7
ET 35mm
the inside rim is getting close to the shock tower I don't have the body on it yet, but when i bounce the front it will hit the tire pretty quick. Was wondering if this was a problem for anyone else.
wondering if the suspension gains neg camber through out its motion, may be I got too much neg camber to start, because if the above statment is true i'll probably have too much when the body goes on, ( as the front isn't loaded, it will still drop a bit with the wieght of the body) so I can back off of it now. If this isn't the case I have no clue, and need help
Old August 5th 2005, 15:10
rip's Avatar
rip rip is offline
what sort of camber are you guys running with wider rims?
