Old October 31st 2005, 07:38
dgluyas's Avatar
dgluyas dgluyas is offline
944 turbo size discs on early mounts?
BIGGER 944 DISCS on Early Arms
Have ; 944T calipers running on thin na rotors at the rear.
Rear is aluminium caliper bracket on standard irs arm.
Am running the thin na disc minus the 21mm spacer.
Want to run thicker turbo size disc at rear.
Is there a disc that is a thick ventillated disc without spacer that would fit at the rear ??
Cheers
David
"Goliath"
