Old October 20th 2010, 16:17
Luismj's Avatar
Luismj Luismj is offline
Originally Posted by Pablo View Post
After studying you pix a little closer I see GM on there, whats the number stamped on it?
Part number GM 90 523 765.
Height 63mm
Height pressed 52mm (Correct 39mm)
Width 67mm
Base center center screw 63mm
I'm work on new adapter base to this solution, you see on the laptop. (center up lap. display)
But only for little clutch, imagine, blow and need remove engine...
CUP2 17x7x9 Brembo.w.Servo&Master.Cylinder/IRS/CB Dropped Spindle
GTI 2.1 16V Turbo Forged/Sapinho/Fueltech EVO-GL
Old October 20th 2010, 16:53
Not the bolt on solution we were looking for then!
Maybe worth investigating some more bearings or some kind of adapter plate...
Unless SteveC knows something that we don't?
I'm not too bothered cause I got this for a song and can sell it on.
Old October 20th 2010, 16:55
Pablo Pablo is offline
OK I've been in the garage retrieving the sleeve from an old box..
By my great powers of measurement I get the PCD of the mount holes to 54mm & the holes are equidistant
Diameter of the input shaft is 20mm at the widest
Length of the sleeve is 60mm
I have a car under wraps (from the weather) with the engine out but the bearing still on, so I could get someone to press the pedal & I can measure the travel of the bearing.
I just have to get the time to unwrap it. cant do so until next week.
An adaptor looks the way to go and easy enough to get made
Old October 20th 2010, 17:20
Thinking economies of scale?
The measurement might give some good indications of what needs to be done in terms of depth and throw BUT how do we measure how much is actuation of the clutch, presumably if we can get the full movement range then it'll be good?
If you do get a chance, measure the bearing too for diameter.
Old October 21st 2010, 04:04
Originally Posted by al_kaholik View Post
Unless SteveC knows something that we don't?.
I bought to fit in a G50 but in the end I decided to stick with the G50 mechanism.
Old October 21st 2010, 04:29
Did think this after reading. Still liking the idea and will be looking more at an adapter, it is a far superior system
Old October 21st 2010, 07:26
tumba tumba is offline
This might be something to have a look at:
http://www.pegasusautoracing.com/pro...asp?RecID=4625
I'm considering it for my Webster Mk dogbox
Old October 21st 2010, 09:10
Its the price that puts me off... Skill the beating I have ansa an adapter for say 10 to 20 quid will do.
My bearing was incredibly cheap, I'm all about making solutions cheaper where possible and that is far too expensive for what is going to be a daily not a full blown race car.
Old October 21st 2010, 09:39
An adaptor looks likley to convert a mainstream bearing to our gearboxes. Looking at whats posted up so far, they will be too tall, so we need a short one where an adaptor brings it to the required length but with enough travel to activate the clutch plate.
I have another box here at work and the TO bearing sits at rest 40mm off the casing and travels 20mm before starting to fall off the end of the sleeve.
So that gives us maximum travel at least with the whole assembly 40mm max height with the adaptor. Although that does not mean it takes 20mm to activate the clutch.
Old November 7th 2010, 19:28
Luismj's Avatar
al_kaholik
i'm sorry for the quality because take the picture and press the slave it so hard....
is more shorter than I specified previously. (pressed 39mm)
http://i712.photobucket.com/albums/w.../IMAGE_872.jpg
http://s712.photobucket.com/albums/w...MAGE_878-1.jpg
http://s712.photobucket.com/albums/w.../IMAGE_875.jpg
http://s712.photobucket.com/albums/w.../IMAGE_874.jpg
http://s712.photobucket.com/albums/w...r/BB_009-7.jpg
Old November 10th 2010, 09:47
Keep meaning to look at the pics when I get home!
Thanks for posting them up
Old November 10th 2010, 10:57
It needs to be about 40 mm at rest though including the adaptor plate.
Im reluctantly going to order the CNC/Willwood slave cylinder & set that up with a master cylinder along side the brake MC up front.
Old November 12th 2010, 06:27
Xellex's Avatar
Xellex Xellex is offline
check this out: they seem to have a bolt-on solution:
http://www.lmb-technik.de/produkte.html
www.vw1303s.com
Old November 12th 2010, 15:25
Thanks Xellex, but thats for the 901 gearbox
Old November 15th 2010, 04:27
Was about to get on that too. Shame really - looks identical to the TOB both I and Luismj have. Some interesting things on their site though
