Dropped spindles will not work with na calipers .The steering arm fouls caliper
The wisest mind has something yet to learn |
What if I move the caliper to the opposing side?
If you understand, you have lost all sense of understanding... |
Then the caliper hits the trailing arms on turn. I've put the NA calipers on dropped spindles, but it does require alot of machining of the spindle for caliper clearance. I prefer to use the socal welded spindles for that application. I've done a handful, and am no longer doing the conversions due to the amount of work required. It's easier to do a 944T setup on a dropped spindle.
Lanner |
With the turbo caliper what is the best choice of spindle for ease of mounting modification? Disc or drum?
