Old October 16th 2010, 09:11
Pablo Pablo is offline
Hydraulic throwout bearing type 1 IRS box
Does anyone have any experience of hydraulic throwout bearings fitted to modern cars that could be retro fitted to a type 1 IRS box?
I'm in the UK so need info on European cars.
I plan in the not to distant future to convert to hydraulic but don't like the CNC pull type slave cylinders, plus the TO bearings neater & eliminates the need for a HD cross shaft etc.
Paul
Old October 16th 2010, 12:19
JIMP JIMP is offline
Hello Paul
I'm also in the process of finding a solution like this, I already have some used ones from BMW, Ford etc to see what fits best. As soon as I have some news I'll let you know with photos etc
Friendly
Dimitrios
Old October 16th 2010, 15:09
Hello Dimitrios,
Thanks, I look forward to your results.
Old October 17th 2010, 05:25
Saab make one but it maybe a little to deep to fit in a Type 1 bell housing.
Old October 18th 2010, 08:22
judgie's Avatar
judgie judgie is offline
have a look into the hewland gearboxes, most of them have a hydralic throwout bearing. if you have a late style box then you can get a bearing that bolts onto the 3 bolt holes that are used to hold the support shaft. think tilton do them along with a few others.
Old October 19th 2010, 09:33
Tim Tim is offline
https://www.burtonpower.com/prod_fil...=70014&PSet=98
Found these on a Ford racing specialist website (UK).
The hard-copy catalogue mentioned that the hydraulic clutch cylinder nose (APC5) has overall depth 80mm from bearing face to mounting face and safe travel of 22mm. It also mentioned that several customers have successfully fabricated their own mounts on gearboxes other than Ford units. Not sure if this can be modified to fit late style T1 gearbox.
Old October 19th 2010, 10:25
As discussed on Volkszone I have one on the way with a throw of c.18mm. I looked at the AP ones and went for the one i did for testing purposes currently.
The burton one looks like a standard Ford one, but the top one mounted onto a piece of billet.
Results will follow...
Old October 19th 2010, 15:41
Interesting stuff guys, keep it coming & thanks.
Anyone know the travel on the VW TO bearing?
Old October 19th 2010, 23:41
Luismj's Avatar
Luismj Luismj is offline
Hello Paul
I'm work in the same solution to type 1 trans. The problem with the stage 2 or 3 clutch more stronger and blow the hydraulic throwout bearings.
if you have stage one try opel vectra 16V.
i'm work to develop one with external truck cylinder to stage 2 ore more,
My room have one collection...
Luis
Old October 20th 2010, 02:32
Hello Luis,
That's one to look for, thanks. I will have the stage 1 clutch.
Any chance you can post that picture of it fitted that is on your laptop?
Paul
Old October 20th 2010, 08:57
That would help greatly.
Now that the toss seller has got it posted it should be moving along swimmingly.
Al
Old October 20th 2010, 13:36
hmmm... Presumably we have the same TOB here Luis?...
Pic from SteveC on Aussie Veedubbers
There is also a thread on Volkszone about this...
And pics of what I've just had delivered. Best pics of the dimensions that I can get as I don't have the micrometer down with me. Note that this one doesn't have a sleeve around it, because its a cheap most likely, but if you are willing to pay the money you can get them with the bellows.
Old October 20th 2010, 15:25
Nice pix Al, do you know what thats off?
Do the mounting holes match the VW sleeve holes?
I guess you will tell more once you have had a look at a gearbox
Old October 20th 2010, 15:31
After studying you pix a little closer I see GM on there, whats the number stamped on it?
Old October 20th 2010, 15:48
Its a GM 55557587 from Saabs with the 1.9 TiD plus assorted other GMs
It matches up with a 16mm master cylinder which opens plenty of options for different mounting types.
As for bolt patterns and the bearing face, I'm nowhere near either so can't look right now. If anyone has a release bearing handy and the sleeve from the gearbox that'd be great. Otherwise I'll have to get the old man to have a look tomorrow
Presumably it'll bolt up if Luis' is the same but its whether it'll mate up to the clutch face
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
