Old October 25th 2003, 00:18
theo_m24 theo_m24 is offline
How should I mount Seats?????
I'm looking at some seats? Should I use the stock base and weld on some brackets..
Any body got any links on seats????
Old November 6th 2003, 01:26
super vw super vw is offline
What seats are you using? I just got done (almost) with both my seat mounting brackets/frames to mouth Porsche 911 seats in my 74 super. it all depends on what seats you are using...?
Old November 6th 2003, 12:21
Bullyboy Bullyboy is offline
you can use stock vw seats if you have the late beetle seat tracks with the hump in the middle. The adjustments needed are minimal. The early 80s scirocco and golf GTI sport seats are a good fit( thats what we have mounted).
Old November 6th 2003, 22:08
craazy Cooter's Avatar
I used leather Recaro late scirocco seats. I cut my origional frames down, and using some bar stock, welded them onto the old seat's tracks. Now they slide in/out and pivot all over. They're
extremely comfortable, and they don't make my arse fall asleep
on long drives. $50 for two at a junkyard.
