Old April 10th 2005, 23:17
flat flat is offline
944 Turbo Brakes for Busses!
Hey guys,
How's 944Turbo brakes sound on your Bus? 298mmx28mm rotors with the Brembo 4-pots, and what's that? "It's bolt-on"!
Bolt on Turbo brakes are now available for VdubCustoms. Fits all buses from 63.5-70. The later buses have to use the 68-70 drum spindles.
See the kit here:
http://www.vdubcustoms.com/Wedo/pbrakes.htm
(Scroll down to near the bottom of the page)
See the install tech here:
http://www.vdubcustoms.com/Tech/tech_944t2T.htm
Easy,
www.vdubengineering.com
Old April 13th 2005, 20:55
sweet. got any plans for a setup for a Vanagon (not that i really need to be going there now, but planning for the future)
Old April 13th 2005, 22:52
Zen,
I could do the 944T setup on the Vanagon spindle, but since the vanagon spindle is a disk spindle, I will need to machine it a little. The conveniece of a drum spindle is that you have some pick-up points to fasten a caliper bracket.
