Old July 15th 2005, 17:20
madpballer232 madpballer232 is offline
how big on stok wheels
how big of a tire can you go on a stock 4 lug wheel. i am getting wider fenders so that isnt a big deal
Old July 15th 2005, 18:53
Uber Affe's Avatar
How big do you want to go?
I've seen some pretty big wheels. Just depends how much modification you want to get into.
Old July 15th 2005, 19:21
let me restate the question. how wide of a tire can you go on a stokc 15 inch 4l ug wheel
Old July 16th 2005, 11:11
oicdn's Avatar
oicdn oicdn is offline
Depends on the offset of the wheel as alot of the aftermarket 15" wheels have a ton of different offsets that fit our car depending on the size tire you go with. I would GUESS around 6 inches. As for a 7 inch 38et wheel, you need 85mm spring coils to have no spacers....
Old July 16th 2005, 12:57
Bullyboy Bullyboy is offline
I have seen 205's on stock wheels but they don't look good with the tire edge sucked way in.
We are running 205/65r15 on the rear with CCC 1.1/4" wider fender and 7" chromies from JBugs and they fit perfect. We have 185/60r15 on 5.5" in the front.
